Vss broke where u bolt to tranny
Old Aug 11, 2009 | 03:21 AM
FarFromStockC70's Avatar
I-Trade!
Default Vss broke where u bolt to tranny
now the bolt isnt stuck into the tranny it the vss it self that broke from the bolt.. so now its just sitting in the tranny... questions i have is
after doing a tranny swap.. bolting everything back together... why is it that my car is idleing funny.. like it has a bouncy idle.. and sometime it dies driving down the road.... i think it was a vaccume leak. cuz now it doesnt do it anymore...
and also.. when you hit the brakes, turn the lights on or anything like seems to turn off.. not like die when your driving down the road.. but like everything turns off and beeps like the car is off but its still running.. any ideas? could this be from the vss or what? because its never done it before...
so ill give you an example. start the car up.. pull out of drive way and well even before i dont have to leave the drive way.. you hit the brakes and the car is stil running ... the RPMs bounce from 1 - 2 and the temp gage hits the roof.. and everything turns off like you would if you turn the key... and the let go of the break and everything is normal... HELP please
if you want you can call me ... at 941 704 4668 name is Joe
thanks in advance...
Originally Posted by omgwtfbbq!
Protip: set your rev limiter BELOW engine speeds that break things.
Old Aug 11, 2009 | 06:45 AM
I-Trade!
Old Aug 11, 2009 | 07:20 AM
Dar_Rell's Avatar
my vss thing broke too, so mine's just sitting in the tranny, the only thing i noticed about it is that sometimes speedo needle bounces as i accelerate, and sometimes it glides smoothly,
have you posted on g2ic.com? you might find a little more help there
TR "Old Skool DA" Member #71
because old's cool
Originally Posted by KanyeWestYo
TampaRacing doesn't care about black people
Old Aug 11, 2009 | 07:43 AM
I-Trade!
yea i did post on there but noone has answered my question... so i dunno... but i dont understand why the car would act like it wants to shut off when im press the breaks or turning the lights on. so thats why i am trying to find out.
Old Aug 11, 2009 | 10:02 AM
custom240sx's Avatar
DC Crew Member #1
Sounds like a wiring short. Maybe you don't have a good ground or your have some plugs crossed.
Old Aug 11, 2009 | 11:14 AM
I-Trade!
does anyone think the cluster is Fuked? i think it is a ground issue ill check everything. is it poss? that a fuse blew somehow?
