attn Mr. Selfdestruct
I have a 90 std Hatchback with a first gen B16. All the wiring is done no codes but not running correctly im wondering if and when you could look at my car. phone number is 727-867-8792 call anytime. please respond if you can or cant so that if you cannot i can find someonelse just in case.
thanks Sean
thanks Sean
Guest
Posts: n/a
when you say it doesnt shut off do you mean it continues running after you turn the key to the off position? Or does it just run for a few extra seconds before shutting off? If it just runs for a few extra seconds sounds like the timing could be outta whack that can also cause a bad idle. Hybrideg doesnt have to work this weekend let him take a look at it.
