integra starting problems
Old Jul 27, 2009 | 12:03 PM
InTeGrAcInG's Avatar
stay thirsty my friends
Default integra starting problems
this shit is crazy. the car will crank up fine but i have to hold the clutch and turn the key multiple time before it will crank. ive replaced battery termanels checked alt and bat and are fine. its like the battery is dead when i turn the key. it just clicks with every turn and then cranks after so many times. what the hell is this?
Old Jul 28, 2009 | 04:56 AM
CertEmt's Avatar
Free bump, wish I could help, Battery? Starter?
Old Jul 28, 2009 | 06:14 AM
FC_V8's Avatar
It sounds like the Starter, try push starting your car and see if it fires right away. Check for bad grounds maybe?
Old Jul 28, 2009 | 01:01 PM
Yeah. Im Thinkin Its The Starter. I'll Replace It And See. Thanks Guys. All Rep'ed.
Old Jul 28, 2009 | 02:14 PM
esean93's Avatar
no its not ur starter.its ur clutch pedal switch.its probably not malfunctioning but next time get up there behind the clucth pedal and push the switch in with ur finger and start the car if it starts right away then the switch may just need to be adjusted.this happened to my car it turned out there was a hole in the clutch pedal where it hits the switch.wierd shit.
Old Jul 28, 2009 | 06:50 PM
FC_V8's Avatar
It cant be the clutch pedal switch because he says it takes a couple try's then it will start. If it was the little plastic piece that broke off and its not hitting the sensor when your step on the clutch then it wouldn't start at all!?! Thats why i was assuming it would be the starter that is going bad.
Old Jul 29, 2009 | 09:03 AM
esean93's Avatar
This happened to my car and it did take a couple of trys to start.I had to to like really stab the clutch in to start it.even if it's not it it's worth a look though.it takes 2 secs to reach behind the clutch and atart it.if it is it he'd save money for a new starter.
If this isn't it then tap on the starter with a hammer
Old Jul 29, 2009 | 10:15 AM
Dar_Rell's Avatar
+1, mine had the same prob.
-sometimes i can start it right up
-sometimes i have to reeeally push on the clutch
-sometimes i have to turn the ign. all the way off, then back on
check around the clutch pedal, then the starter
TR "Old Skool DA" Member #71
because old's cool
Originally Posted by KanyeWestYo
TampaRacing doesn't care about black people
Old Jul 29, 2009 | 12:44 PM
ill be checkin it today. rep'd
