1994 Accord turn signal relay?
Old Jul 22, 2009 | 09:27 AM
j99jm's Avatar
Default 1994 Accord turn signal relay?
Can anyone tell me where to find the location of the turn signal relay for a 1994 Accord? I know it's somewhere around the fuse box, but i'm not sure which one it is... Thanks!
Old Jul 22, 2009 | 11:41 PM
Generally, it is on the back side of a fuse block. Press the side
of the relay to release it......remove one from a junkyard first, and
that tells you how to remove yours. Sometimes the relay will be labelled, sometimes the place where it goes will be labelled. Sometimes you need a mirror and a flashlight to read the lettering.-Bob
Old Jul 24, 2009 | 02:52 PM
j99jm's Avatar
Thanks, but I found it.. If anyone needs to know, it's above the fust box on the left side or towards the back of the car. It is black, and when you take it out it says "turn" behind it.
