Need Help On My Integra Plz....
if its 4 then its your crank position sensor, depending on the year the crank position sensor on a 88-95 is located in the distributor, 96-01 the crank position sensor is located behind the crank pulley and in the distributor, but since you changed the distributor or tried other distributors like you said then it's the one behind the crank pulley
oh and code 6 is your water temp sensor
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Non-VTEC:$20-up
VTEC:$40-up
fix code 4. that is your problem
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
thankz alot yall im gonn see all dat early in da morning wit my mechanic then ill tell yall if its fix...
96 ek hatch
93 eg B16
92 eg H22
08 ex civic
99 ek D16v
94 ls. integra
93 eg ls-t
2004 is300 DD
+1 on limp mode.-Bob
iight keep us updated
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
well this is wut me and the mechanic found out...we check the voltage on the fuel pump and its getting too much..its supose to be getting only 12 and its almost in 14 so we think electrical problem...i can start up the car and its gonn work ok till i put 1st gear and thecar start moving...AND THERES NO CRANK POSITION SENSOR BEHIND THE CRANK PULLEY....
96 ek hatch
93 eg B16
92 eg H22
08 ex civic
99 ek D16v
94 ls. integra
93 eg ls-t
2004 is300 DD
what year is your integra?
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
from 96-00 integra, it should look like this
If you dont have it and you have a 96-00 integra is why it running that code and not running right, you need that sensor, who care if you fuel pump has 14v not 12v, it would not cause your car to run like crap, probably the reason the fuel pump is running more voltage then usual is because you have a bigger fuse on the main relay side that is making it distribute more volts
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
my car is a 94...AND I DONT HAVE A BIGGER FUSE NOWHERE I HAVENT TOUCH NON OF DAT STUFF...
96 ek hatch
93 eg B16
92 eg H22
08 ex civic
99 ek D16v
94 ls. integra
93 eg ls-t
2004 is300 DD
94 so then its your distributor, it has to be a bigger fuse to have more volts you talking to a guy that been there done that........ certified auto tech,
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
