one more time * motor mounts*
Old Jul 12, 2009 | 08:23 PM
got_bst?'s Avatar
Passed you
Default one more time * motor mounts*
alright i have 89 dx crx with a d16a6 swap
i would like new mounts
i had a previous thread in which a person mentioned a company to buy them from
i only have the two sides and the rear the front mount was cut out because it had a b18 in there b4 the d16 was put in
what company makes these mounts and which one is the most reputable
Thanks T.R
Old Jul 13, 2009 | 01:01 AM
AllShowNoGo's Avatar
Auto Zone
Old Jul 13, 2009 | 06:26 AM
got_bst?'s Avatar
Passed you
Kidding right?^
Old Jul 13, 2009 | 11:49 AM
KJ's Avatar
KJ
bored at work
Get stock mounts and get the mount inserts. I don't think I've ever seen aftermarket solid bushing mounts for ef with the stock motor.
Old Jul 13, 2009 | 07:06 PM
got_bst?'s Avatar
Passed you
well who makes inserts then?
Old Jul 15, 2009 | 12:19 AM
I have seen inserts for some Hondas at Pep Boys........-Bob
Old Jul 15, 2009 | 12:32 AM
dude your single cam is fine with stock mounts its not like your pulling any big hp out of it like i said AUTO ZONE
Old Jul 15, 2009 | 12:35 AM
SuburbanNoize's Avatar
Cold Ass Honky
You can check energy suspension for the mount inserts.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Jul 16, 2009 | 05:20 AM
got_bst?'s Avatar
Passed you
the D is getting boosted soon till it blows and then i will get a b swap
Old Jul 18, 2009 | 06:34 PM
FrodoGT's Avatar
Found the Vtec switch.
Hasport makes a stock replacement mount kit for the EF that only uses those 3 mounts. They are billet and can be ordered in different stiffnesses. Just as long as your block isnt going to be swapped for a 92+ piece then your fine. If it is, youll have to go to innovative and have them make you a set. Just tell them your using an obd1/2 block and they'll account for the slight twist that you get with stock fitment mounts. Hasport currently does not make a driver side mount that will fit an EF with a block that isnt from the same generation, a stock mount flexes enough to fit but solid ones just dont give enough to make it line up.
TR Old Skool EF Crew #24
