spring installed incorrectly ?????
Old Feb 18, 2002 | 03:47 PM
Spence's Avatar
"TEAM WHITEY"
I was woundering if lowering springs could be installed correctly because i thought the neuspeed racing springs would give me a larger drop and i really dont trust the people that installed them also if i cut the bumpstops in half will that give me any more drop of just a bettr ride!!!!!!
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Feb 18, 2002 | 04:00 PM
Gibbon's Avatar
twisted logic
A neuspeed race set-up will drop your front about 2.25 inches and the rear will be around 2.0 inches. The car will set in (or get a little lower) in about a week. The front tires should be tucked in and the rear should be very close to tucking under. As far as the bumpstops..... im not sure. I think it has something to due with performance so it would be wise to cut them like neuspeed suggests. Hope this helps.
Old Feb 18, 2002 | 05:57 PM
Bill's Avatar
Livin' in Seattle
Yes anything can be installed incorrectly if one tries hard enough.
What exactly is it that you think is wrong?
As for the bumpstops the reason you need to cut them on some applications is because the car sits so much lower than it did originally that you will begin to come in constant contact with the bumpstops creating a much harsher ride.
Old Feb 18, 2002 | 06:01 PM
Spence's Avatar
"TEAM WHITEY"
Well i have a friend that has a 97 with these springs on his ride and says it lowered his car a ton i have never seen car to see how really low the car is. Also this is the lowest drop that is possible with springs and it just does not look like its that much with the accord. I thought it was the wheels size when i had 15s but i just put 17s on and it still does not put the wheels in the wheel well that much!!!!!!
Old Feb 18, 2002 | 08:36 PM
88EFSiR1J1's Avatar
why do you want to go so low? TRUST ME you dont want to be to low I just banged the hell out of my new header and I still feel like itll never be the same Im actually getting rid of my springs now and installing some H&R sport springs to raise it up again those are only a 1.5 inch drop so I wont continue to fuck up my under carage. just something to think about
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Feb 18, 2002 | 09:52 PM
chet's Avatar
All Aboard
lower your car 2 inches its the perfect compromise and offers the best handling without sacrificing the integrity of the car over bumps potholes and whatever else you may hit while driving.
Old Feb 19, 2002 | 06:20 AM
88EFSiR1J1's Avatar
not every car is the same can you drop 2 inch without getting a 4-1 to hit bottom?
14.729 @ 94.79
Laser Red
Jun 28, 2000 03:07 PM
