My foglight went out
Old Jun 29, 2009 | 02:02 PM
Gradd3000's Avatar
Default My foglight went out
alirght i got a 99-00 style yellow foglight on my civic. Once in a while they would go out so i pull the fuse out and plug it back in and they turn on again. well now only my left foglight wont turn on. may its a bulb. can someone tell me what size bulb i need and where can i get it? also can someone tell me what amp fuse i should be using?
Old Jun 29, 2009 | 04:03 PM
thegoldenchild's Avatar
they are h3
Old Jun 30, 2009 | 07:50 AM
Gradd3000's Avatar
Old Jun 30, 2009 | 08:58 AM
extatic002's Avatar
is an asshole
why the bump? you got an answer..heres an even more simplified answer just incase you dont believe ^^
take the bulb out
put it in your pocket
Go to store(autozone or some shit)
Pull out of pocket
go to isle with bulbs
Compare til you find one that looks the same
Buy it
Put it in
and done
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old Jun 30, 2009 | 12:22 PM
Originally Posted by extatic002
take the bulb out put it in your pocket
Go to store(autozone etc)
Pull out of pocket
Buy it Put it in and done
+1 In addition, I put a non-oxidizing phone company grease on the contacts. You might also do a continuity test to see if the bulb is dead, or it you have a wiring problem.
If the fuse were blowing, the amperage might be important.
If you want someone to look at it, get back with me.-No charge.-Bob
