new head and wont start?
Old Jun 10, 2009 | 10:07 PM
JDM Killer's Avatar
Cops h8 me, bitches <3 me
maybe if u get that missing sensor, Hmmm..
Old Jun 10, 2009 | 10:18 PM
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Missing sensor wouldn't give such low numbers on a compression test
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds TR "Old Skool DA" Member #91Still Jokie!!!!!!!!!
Old Jun 10, 2009 | 11:05 PM
mr.hatch's Avatar
EKallday
i had it pop twice but i think it was just gas left in there that didnt get burned from when i previously tryed starting it but i aint for sure but all it does is crank but its SOOO close to starting because i can hear it but it just wont start
Old Jun 10, 2009 | 11:08 PM
Jspec94LUDE's Avatar
ROLLIN UP STANKY!!!
do a compression test first off , then check for fuel and spark
ROLLIN UP STANKY!!!
if all else fails replace your dangle switch i believe its under your battery
Old Jun 11, 2009 | 05:25 AM
JoKiE crx4294's Avatar
popeye built!
why dont you have corey fix it?
Can't spell strength without tren
AAS...It's whats for dinner
Old Jun 11, 2009 | 09:19 AM
  #17 (permalink)
mr.hatch's Avatar
EKallday
i have shity compression i posted that ^ and i have spark and fuel going down because i can smell it on the plugs
Old Jun 11, 2009 | 09:21 AM
  #18 (permalink)
ROLLIN UP STANKY!!!
well check your valve adjustment it could be tight and holding your valves open , u want .008 on all valves for stock cams i run .009 on big aftermarket cams
Old Jun 11, 2009 | 09:22 AM
  #19 (permalink)
ROLLIN UP STANKY!!!
did u take all your valves out and at least hand lap them in????
Old Jun 11, 2009 | 11:01 AM
  #20 (permalink)
97EJ-6's Avatar
Kiss Mi Ras!!!!!!
Actually you would want .006 intake and .008 exhaust if that doesn't solve it you have bent valves or if the head was pulled apart the valves weren't lapped
