Need sohc help lol
Old Jun 8, 2009 | 06:30 PM
JoeySutnick's Avatar
Default Need sohc help lol
Ok tr I am doing a hi comp d16z6 build and I accidently bought a 75.5mm cometic headgasket will it work or no pm me thanks in advanced bump if u view I'll rep thanks
Old Jun 9, 2009 | 08:33 AM
Old Jun 9, 2009 | 08:49 AM
willie_massacre's Avatar
Lives in a square
bump.
Old Jun 9, 2009 | 11:33 AM
thanks^
Old Jun 9, 2009 | 11:44 AM
shane thrasher's Avatar
If you bought it from like a website or a shop, Why don't you just contact them and ask. Just wondering how high of compression are you going?
Old Jun 9, 2009 | 12:34 PM
EconoBox's Avatar
Four Door Mafia
It is "iffy" yes it probably will work and yes it may make it blow. The gasket is still going to sit on the sleeve area just not flush with the wall of the cylinder. As long as all of the other holes still line up properly, which they will if the gasket is for the right motor.
This is what it will look like on one side once it is put together. It may or may not effect your compression ratio and it may or may not cause problems down the road. But why take a chance contact the seller and see if they can help you out in any way.
(headgasket is the black area)
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Jun 9, 2009 | 01:51 PM
^i bought it from gearhead and blaze said it will work with no problems...
Old Jun 9, 2009 | 01:52 PM
12 to 1 pretty suree. p29's it a z6. stock bore
