This is a Dumb ? but im knew so thats ok
is there any wrong way to put an intake on a 97 prelude? me and my buds put a aem cold air i was just making sure that hissing noise that i hear is sposed to be normal...sucks in alot of air though
. because i know i heard that hissing noise when i took my intake off one time
Guest
Posts: n/a
its kinda hard to screw up an intake install most intakes do his however there are different types of hisses there is a normal his and there is an air leaking hiss. Start your car up pop the hood. Or you can pop the hood then start the car that part doesnt really matter
then just take your finger and gently slide it around the seals of the intake if the hissing goes away when your finger is at a certain area you have a leak there if you go over all the seals and still have the hiss then you just have a normal his that most high flow air filters have.
ok....your new and so far on the right track but plese remmember stickersaltezzas and wings dont look good no matter what your friend says. anyway good luck with the prelude!
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
