help: Condenser Fan not switching on
ROTM March 2013
on
Car: 00 Civic Dx
Took the car to have the a/c charged with refrigerant today and found out the condenser fan isn't coming on like its supposed to. I jumped the condenser fan to the battery and it functions perfectly. I check checked and replaced the relay for the compressor and the one for the condenser fan. I checked the fan fuse and that was also good. I checked power at the relay terminals and at the fuse terminal and all were good.
It seems like something isn't sending power to the fan to kick on when needed.
A/C blows cold until the condenser gets too hot.
Can anyone help with this issue?
engine building &best
on
the plug that turns the fan on is under the dash on the Evap box
i love AUTOZONE
i love AUTOZONE
on
i replaced my whole ac system and was pissed when i could not get it to work then i double checked everything and i forgot to plug that plug back in now its works just check that out to see if it could be the problem
i love AUTOZONE
i love AUTOZONE
there is a sensor on the Dryer under the hood.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
check both.. make sure they are pluged in. The condesor relay is under the hood fuse box.
727-510-6301
