need help
Old May 29, 2009 | 11:13 AM
93eg's Avatar
Default need help
i just got my d16z6 back from gettin fixed i got it back into the car pluged everything up it will turn over just wont fire any ideas im not that good with cars but hey its a single cam what can be so hard lol lmk if you have any ideas that can help me out thanks
Old May 29, 2009 | 11:40 AM
jcarp613's Avatar
Check your ground that bolts to the thermostat housing...
1990 Acura integra Part out! DA. Doors, Catback, Windshield, Wing, Etc...
https://www.tamparacing.com/forums/h...ml#post8243584
D15B2, 5spd Cable Tranny, Dizzy, A/C Parts, Starter, Axles, Tons of D Parts
https://www.tamparacing.com/forums/h...s-d-parts.html
Old May 29, 2009 | 11:50 AM
93eg's Avatar
i got all the grounds hooked up im about to go get a little bit of gas its really low maybe thats it but idk evrything is hooked up right to my knowledge but im not really good with cars so idk what about vacum maybe thats not hooked up right would that effect it to not start at all?
Old May 29, 2009 | 11:57 AM
Nandosol's Avatar
Garage Slut
Spark, Fuel, Compression
Old May 29, 2009 | 12:00 PM
jcarp613's Avatar
Start with fuel. Can you hear the pump kick on? Check for spark. Start with the basics.. There are 2 clips on the wiring harness that if you have them reversed, you won't start. Very common problem...
Old May 29, 2009 | 12:36 PM
93eg's Avatar
well i got some gas and that helped but it still wont start all the way the most i can get out of it is 2 maybe 3 pops but i wont stay runnin
Old May 29, 2009 | 07:08 PM
jcarp613's Avatar
That sounds like your timing belt is off by a tooth.
Old May 29, 2009 | 07:22 PM
thegoldenchild's Avatar
or wires are in wrong order
Old May 29, 2009 | 08:58 PM
93eg's Avatar
well a buddy of mine fixed my motor i spun a bearing and had to get a new crank and bearing and he is really good with hondas so im pretty sure timming is ok and compession i got spark on piston 1 2 3 but i think my 4th wire is fucked up would that effect it but it was running fine when i had it in before i spun a bearing idk if im completly sure on all the clips but it seems pretty easy so idk help me please lol
Old May 29, 2009 | 08:59 PM
93eg's Avatar
and which 2 clips are easy to mix up jcarp613
