HELP!! Overheating and Manifold Pressure?
there was no loss of power or anything, I stopped at a redlight, saw smoke and smelled coolant, I pulled over, as soon as I looked under the hood steam was shooting downwards from where I show in the pic... when I took the tube off there was lingering steam inside the tube (most likely from the intake) like I said I replaced gaskets less than 2 months ago so if some hose was mixed up wouldnt I have noticed sooner?
theres your leak under the throttle body, the bold circle is a water hose, the skinny circle shows the clamp that should be on the bold circle so it wont leak ,problem solved and thats 215 thank me later
wow.... yes that hose clamp isnt on, but I know that even if it was leaking from there (i said a few times now its not a hose leak) that still wouldnt explain the steam INSIDE my intake...
