best cams for boosted b18
Old May 19, 2009 | 12:05 PM
  #21 (permalink)
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
You're planning on making 500wheel with that setup?
-Winston Churchill
Old May 19, 2009 | 12:12 PM
  #22 (permalink)
lilbenz_22's Avatar
i have seen well over 400 plenty of times with it just looking for the last bit
Old May 19, 2009 | 02:13 PM
  #23 (permalink)
JoKiE crx4294's Avatar
popeye built!
Originally Posted by lilbenz_22
weed whacker, old volvo, gold platted as long as there is 18 psi in the intake doesnt matter how it got there. Im eventually going to upgrade turbo and mani but waiting till this shit breaks. shit gets expensive quick
the manifold isnt that bad actually if its braced right.
Can't spell strength without tren
AAS...It's whats for dinner
Old May 20, 2009 | 09:23 PM
  #24 (permalink)
AllShowNoGo's Avatar
Attachment 118516(1)
Hybrid Turbo Charger:
.57 compressor wheel trim mapped for low & high boost setups
wet float bearings & properly balanced
3" inlet diameter with a 2" outlet
.50 A/R compressor housing
.63 A/R turbine housing
1/8 NPT oil inlet
T3/T4 hybrid
(1) Turbo Exhaust Manifold:
TIG welded 321 Stainless steel
Fully ported and polished design
also just put on a three in downpipe with full three inch staniless all the way back not cat and a forza 3in inlet 4.5in out. have a skunk two intak manifold. right now have gsr cams, adjustable cam gears, 8.5 to 1 compression pistion and all arp bolts. I have a chipped obd1 with msd sci ignition, walbro 255, adj fpr, 880cc injectors
badass, we are all workin for those high numbers just takes time!
