sohc vtec swap
Old May 16, 2009 | 08:04 PM
got_bst?'s Avatar
Passed you
Default sohc vtec swap
Hey T.R i did some searching and did not find a lot of info so i am here to ask you guys.
I currently have a d16a6 in my rex - is there a Vtec head swap i can put on it? And were the fuck can i buy pistons and rods for my D? Thank you & bump if u view
Old May 16, 2009 | 08:16 PM
got_bst?'s Avatar
Passed you
also in need for a dseries manuel tranny conversion that will fit on a d17 need it for a friend thanks. If anyone has the complete swap lemme know
Old May 17, 2009 | 04:24 AM
Jun_Tuning's Avatar
VTEChnician
yea D16A6 to D16Z6 Conversion..."Mini-Me" , TunerToys - Turbocharging, Supercharging, and Performance products for your car!
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Old May 17, 2009 | 06:04 AM
got_bst?'s Avatar
Passed you
thank you ^
Old May 17, 2009 | 07:00 AM
chi town brat's Avatar
! Ne shab'rud'ni !
Moved to the correct forum for tech.
chi town brat
S Mod
Old May 17, 2009 | 07:31 AM
got_bst?'s Avatar
Passed you
Thank you. Found some more info on the swap, and been talking to some people and they say that a b16 is something i should look into since i am a beginner. Thoughts on that? I know you can rev the piss out of those engines but what can i expect from doing that swap? My ultimate goal right now is 3-350 Wheel on boost. Can i achieve this easier with a B16 or is it the same shit?
Old May 17, 2009 | 07:36 AM
FrodoGT's Avatar
Found the Vtec switch.
To get get 300-350 whp on either one your going to have to do the same shit, and the b series stuff is more expensive. If you wanted a power level that wouldnt require replacing the the internals etc then the b series will make more power stock for stock.
TR Old Skool EF Crew #24
Old May 17, 2009 | 07:45 AM
got_bst?'s Avatar
Passed you
So regardless i would have to get internals. How much boost can good internals hold? I have seen some build with 600+ h/p If i have to do internals and all that shit i might as well do it right the 1st time. So cheap = zc swap stock with low boost. Pricey but better in long run = B16 swap with internals on boost. I think i made a choice. What cv's do i have to use for the swap i've read that you can use da once or something along those line i've also seen some sold to fit my car with a b-series swap.
Old May 17, 2009 | 08:38 AM
FrodoGT's Avatar
I wouldnt build a b16, while your doing it you might as well build a b18..
If you want the cheaper route to your goal go to turbod16.com
a 350whp sohc can be had for about 700 roughly.
Old May 17, 2009 | 08:45 AM
got_bst?'s Avatar
Passed you
really? My thing is i know further down the road i will want to get a b series engine. What is the overall advantage of a b18 besides the .2 more displacement?
