hey tr spark problem
Old May 14, 2009 | 05:00 PM
cabron's Avatar
Default hey tr spark problem
hey tr i have a 89 crx with a ls in it n for some resend its not passing spark no more i put a new dizz n its still not passing no spark what can it be lmk
Old May 15, 2009 | 04:51 PM
cabron's Avatar
TR "eg" crew #37
Old May 15, 2009 | 06:13 PM
jcarp613's Avatar
Most likely a ground wire. There is a ground wire theat bolts by your dizzy on the Coolant neck. Try that and LMK. Check all of your grounds...
1990 Acura integra Part out! DA. Doors, Catback, Windshield, Wing, Etc...
https://www.tamparacing.com/forums/h...ml#post8243584
D15B2, 5spd Cable Tranny, Dizzy, A/C Parts, Starter, Axles, Tons of D Parts
https://www.tamparacing.com/forums/h...s-d-parts.html
Old May 16, 2009 | 07:25 AM
cabron's Avatar
ok i will check
TR "eg" crew #37
Old May 16, 2009 | 05:34 PM
PeteStop's Avatar
We can build your dream!
Originally Posted by cabron
ok i will check
Also check to make sure your getting 12 volts to your coil and a neg pulse while turning over!
PETE STOP
3991 Park Blvd
Pinellas Park, FL 33781
www.Petestopmotorco.com
PERFORMANCE, INSTALLATION,REPAIR,Nitrous fills, Mon-Fri 9-6 Sat 9-5
Complete Repair, Import,Domestic
Forced Induction, Bolt on, custom, alcohol, Nos
COMPLETE INTERIOR, Custom everything
Import tuning by, Carter Taliaferro
Domestic tuning by, Pete Stop- tuner of your choice.
If your not first your last!
727-541-3400
Old May 17, 2009 | 06:42 AM
cabron's Avatar
the ecu is not geting any signow
TR "eg" crew #37
Old May 17, 2009 | 06:45 AM
cabron's Avatar
the ecu is not getting no signow can it be the main relay
TR "eg" crew #37
Old May 19, 2009 | 02:55 PM
cabron's Avatar
TR "eg" crew #37
