Help! Car wont start...
mowchowbrowncow
on
okay guys i recently got a ef hatch with a b20 swap n it ran fine for a few days...but kinda struggled to turn over but would start n run fine...now one morning it just wouldnt start.
Iv replaced fuel pump,fuel filter,Ngk iridium cold start plugs,& also took my neal sutton ecu out n put in a oem Pr4...Also did a compression check everything came back solid.
I really dont have the cash to send the car out so wanna get some other opinions...
Only thing i was thinking is maybe my fpr is bad or dizzy is shot.
Start with the basics... Is it getting spark? Fuel? Put a spark plug on 1 wire at a time and with the metal touching the metal of the car, crank it to see if you are getting spark. If not, most likely the coil in your dizzy. Fuel.. Turn your key to the on position. Do you hear the pump turn on? If not, most likely the main relay. Keep us posted....
1990 Acura integra Part out! DA. Doors, Catback, Windshield, Wing, Etc...
https://www.tamparacing.com/forums/h...ml#post8243584
D15B2, 5spd Cable Tranny, Dizzy, A/C Parts, Starter, Axles, Tons of D Parts
https://www.tamparacing.com/forums/h...s-d-parts.html
mowchowbrowncow
on
i just put a walbro 255 in it,fuel filter,& spark plugs minutes ago...tested all cylinders there getting spark n fuel...injectors are fresh has a full obd1 neal sutton wiring harness /w obd2 injectors
engine building &best
on
try a different distributor that sounds like your problem
i love AUTOZONE
i love AUTOZONE
Jumped a tooth on the timing belt? OBD2 Injectors on an OBD1?
mowchowbrowncow
on
