Fuel pressure question
I race sailboats
on
So I just installed a fuel pressure gauge and upped the fuel pressure to help reduce the knock issue I've had for a while now. Base pressure was 50psi, and I'm currently at 67 with no bogging issues at all through the rev range. But, I still have knock at partial throttle in 3rd, 4th, and 5th. I was wondering how high some of you guys have gone on your set ups, and how much higher can I push the pressure?
Setpup is a 98+ B18C, AEM CAI, Apex'i N1, stock ECU.
I don't know much about what you're trying to achieve but with a stock motor an 93 octane fuel, you shouldn't be knocking at all, especially at 50-55psi. I would try either some bigger injectors or send out the ones you have to get cleaned and flow tested.
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
Upping your fuel pressure is not necessarily going to help with knock/pinging.
You should be making sure your distributor (ignition) timing is not advanced.
Exactly what he said. How do you know you're "knocking". You shouldn't be knocking with the setup you listed, ever
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
I race sailboats
on
I'm running 93, I have the timing set to 14 degrees. As far as the knock is concerned I've had two different performance shop owners diagnose the problem with the same result. My injectors may be the issue, I've never had them cleaned or flow tested, are there any recommended places to which I could send them?
I race sailboats
on
Im sure its stock, its also the correct one for the engine. Its rather hard to find a Tuner such as Alpha or yourself John, the closest I could get to conveniently would be Jestr, and hes only in Orlando at random intervals.
