spark plugs
Guest
Posts: n/a
y35 4ll B 53|2135 m070|25 u53 7h3 54m3 plug 7h|234d1|\|g bu7 7h3 |\|0|\| v73c u53 h0773|2 plug5 1f 1m |\|07 m1574k3|\|.
4ll 7h3 1|21d1um5 4pp4|23|\|7ly 4|23 m4|\|uf4c7u|23d by Ch4mp10|\| \^/h37h3|2 7h3y 4|23 l4b3l3d 45 5uch 0|2 07h3|2\^/153. 7h3 Z3>< plug5 4|23 c|24p 1v3 533|\| 4 g41|\| 0f 5hp by g01|\|g b4ck 70 |\|GK5. 1d 571ll u53 |\|GK c0pp3|25 1f 7h3y \^/3|23 7h3 54m3 p|21c3 45 pl471|\|um5.
1f y0u \^/4|\||\|4 5p3|\|d 7h3 71m3 4|\|d dy|\|0 17 J03 1 h4v3 |\|0 p|20bl3m \^/17h 7h47.
Where can I get my hand on some NGK copper cold plugs?
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
Info from the ngk site states that the oem plug in the gsr has a gap of .052 the type r plug has a gap of .044. the heat rating number is the same its 6. The LS takes a hotter number five heat rated plug. So It seems as though if you run the same heat range as the stock plug and the same gap as the stock plug(On a stock engine) then everything should be o.k. with switching from platinum to copper.
Discount? I know its a long shot but you have a part number?
14.729 @ 94.79
14.729 @ 94.79
