Need Help!!! BADLY
Need Help!!! BADLY
Well here is what i got. 95 civic dx with B18B. The problem is it wont turn over. it clicks and clicks and clicks but no spark. Check the ECU and its code 15 Ignition Output Signal, and i don't/cant find out where to look for it to either A. change it or B. fix the wiring..
MUCH HELP NEEDED. WOULD BE GREATLY APPRECIATED!!!
message me on here or hit me up cell 727 505 4960 Jeremy
are you aware that turn over means to actually have the starter engage and to cause the engine to rotate? or do you mean it is rotating and it wont start?
"Black people can't be racist" - Some black guy.
i dont know why everyone gets those 2 confused....anyway
just out of the blue? or did you do a swap and it never ran? according to the OEM service manual, its either the ignitor (in the dizzy) or the wiring to/from it.
FYI you can get OEM service manuals here:
Hondahookup.com - Honda / Acura Aftermarket Parts, Accessories, Forums, Photo Galleries, Racing, and more!
What do i look for on there??
Check the thick black with a yellow stripe wire at the distributor. It should have power when the key is in the run position. That is the main power for the distributor.
