location of a relay
Old Apr 19, 2009 | 05:40 PM
acuralsb18's Avatar
Exclamation location of a relay
need to no were the a/c relay is located at on a da need to no asap
TR "Old Skool DA" Member #17
Old Apr 19, 2009 | 05:53 PM
Thatguysstuff's Avatar
Hey its that guy!!
what year?
Old Apr 19, 2009 | 06:24 PM
acuralsb18's Avatar
a da 92
Old Apr 20, 2009 | 07:11 AM
Hey its that guy!!
Well a Da is 90-93.. and the 90-91 are diff from the 92-93..
probably located in the fuse box up front.. under the hood.
Old Apr 20, 2009 | 08:29 AM
Default Testing for a bad relay
Pick a relay slot where things are working as they should....... and if they are the same part numbers, test them all in that slot, If it clicks on, that will tell you if your relay is good. No click is bad. Repeated clicks
are bad.-Bob
Originally Posted by Thatguysstuff
Well a Da is 90-93.. and the 90-91 are diff from the 92-93.. probably located in the fuse box up front.. under the hood.
