egr valve on h22
Old Apr 14, 2009 | 08:44 AM
eightwun3zfynest's Avatar
sleeper
Default egr valve on h22
i was wondering if i need to connect the egr valve? can i run the motor without it being plugged in? .. im using a p28 chipped ecu .. the swap is goin into a 93 del sol...
Old Apr 14, 2009 | 10:23 AM
sleeper
wow 5 views and no1 knows .. thanks tr your a great help ..
Old Apr 14, 2009 | 11:00 AM
PooN_Lude's Avatar
Out of 5 people, no one knew the anwser to your question, and you give an attitude. wtf
Maybe you should have done some more research on the swap before attempting it, you have a different thread every day with some problem you've run in to.
Have your chipped ecu not check for egr and run a block off plate.
Old Apr 14, 2009 | 11:53 AM
sleeper
ok ..
Old Apr 14, 2009 | 12:23 PM
vonrobins's Avatar
love hondas ftw
i like your answering skills
._________________________
Old Apr 14, 2009 | 09:42 PM
96spydergst's Avatar
Default ....
I used a b18c throttle body on my H22A1 setup. It has the MAP-TPS-FIV all on it. I was using the original TB and it had the MAP off of it and shit. this was easy. All so you donot need the EGR.
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
Old Apr 15, 2009 | 04:15 AM
sleeper
ok ... im using the oem throttl body ..
