need help!!!!!
previously kid420
on
need help!!!!!
so i have a 91 hatch with a dpfi d15 and its running like shit ,it starts to bog when i press the gas pedal all the way down i have to play with it , it also turns off when im coming to a stop if i have less than half a tank of gas ,and last night it just got a whole of a lot worse the car would not want to go at all!!! it just hesitated to go and would back fire a whole lot , i allready changed fuel filter, spark plugs,and spark plug wires they made it run a lil better but the problem is still there so im pretty sure is somenthing with the fuel, im thinking i should drop the gas tank and maybe clean i out or somenthing what do you guys think it is???????? maybe o2 sensor?????
I am thinking if your fuel pump is still from when they installed it in 1990 (more than likely the year built like mine was) then it may be on its way out because with half of tank it dies out.
you may have also gotten a bad tank of gas.
how did the gas smell when you replaced the filter? how dirty were the spark plugs when you replaced them?
by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
previously kid420
on
there very well could be rust in the tank. best bet is to drop the tank, drain it and use a strainer to see what comes out.
check the sock on the fuel pump to see what kind of garbage it caught before it went through your fuel line. then clean that (the sock) as well.
after you put things back together and load up on new fuel I would add a fuel injector cleaner to the tank.
it sucks that you have to drop the tank and then get to the fuel pump on the EF. be prepared for a lot of road crud to hit your face, wear safety glasses.
previously kid420
on
possibly could have been the sock is kinda like a pre filter so to speak it will keep "chunks" of stuff out of the pump thus not clogging and losing fuel or gettin dirty fuel i work in the field but do not claim to be professional lol but sounds reasonable keep us updated thanks
so when you removed the pump the sock wasn't on it ... or did it fall off as you removed the pump?
did you replace the pump with a new one or just put it back together?
how is the car running now?
i loved my little d15 motor ... after 200k + miles the carbon wiped right off the pistons
previously kid420
on
if the sock was off and the fuel from the filter war orange, change the pump and sock just because if its not bad it will be.
"Black people can't be racist" - Some black guy.
