Axle problem...
Old Jan 11, 2002 | 03:25 PM
RicerX's Avatar
Icy Hot Stuntin
Im trying to change my passenger side axle on my b16a1 CRX.
Im having some difficulty.
When I slide the new axle into place it only goes in 3/4 of the way in and stops. It will NOT go any further. The old busted axle goes in all the way with no problem at all. Both the new and the old axles are identical axles from Autozone.
The teeth on both axles are identical and not damaged at all.
Is there something that Im doing wrong?
Any insight would be much apprietiated.
Thanks
Mike.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old Jan 11, 2002 | 09:03 PM
GOTTI's Avatar
OEM Parts Specialist
he said Lubrication
Old Jan 11, 2002 | 09:47 PM
b16a2pwr's Avatar
ALLJDM
have you tried to twist it and slam it with a hammer (LIGHTLY to assist it)?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Jan 11, 2002 | 09:56 PM
RicerX's Avatar
Icy Hot Stuntin
Ive tried twisting it around but I have not tried slamming it in or hammering it. I didnt want to force it too hard because I didnt want to risk damaging any of the teeth/gears on the axle or in the tranny.
I guess next try would be a little light hammering...
Thanks for the input.
Old Jan 11, 2002 | 10:00 PM
b16a2pwr's Avatar
ALLJDM
are you sure that its the right axle?
that might be someting good to check!
also grease the end of it to help it SLIDE right in there! AWE YES
AIM: jasonbadler
813.508.PLAN (7526)
Old Jan 12, 2002 | 07:24 AM
RicerX's Avatar
Icy Hot Stuntin
Yeah Im sure its the correct axle. It is identical to the old axle. Same part number and everything.
I will try to grease it up alittle and try wackin it in there.
Thanks.
Old Jan 13, 2002 | 12:16 PM
RicerX's Avatar
Icy Hot Stuntin
My axle is in and the Rex is back on the road!
You guys were right...I used a rubber mallet and it popped in.
