ok i ran into a problem on my h22 swap into del sol
well i got my distributor and i was hooking everythin up so i can start it up finally .. and i noticed that my fuel line going from the fuel filter to the fuel rail is to short does any1 know where i can get a longer one? and if not what can i do??
just buy some steel braided line, cut the rubber part out of the old one and clamp the ends to the steel braided one and u will be fine... clamp it hard u dont want leaks!!
ill have to move it to the bottom of the driver side under motor kinda like it is on the 5th gen prelude .. and i tried using the same lines thats on the prelude on my sol and the fittings nor the length match up .. sooo im kinda stuck .. dont got money to get steel braided lines .. im using the hasport mount set up ... but my fuel filter is on one side of the motor and where the line screws on to the fuel rail is on the other side ..
Man dude I wish my problems were that easy, I would have fuel line on the way.Do you know how hard it is to find A sohc vtec uncut harness?
Good luck bro. And I got a ECM it was not the prob. I think it is 180 degres out. And it has a after market crankpully so I cant see to line up the crank to see if it off a tooth or to. I have no impact anymore to I just found out (mumbling curse word).
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
I did the same swap into my cousins DC Teg and we had the same problem..We ended up going to some hose/hardware store and having them make it longer..it was only like 20$ or so...you might want to try something along those lines...
G/L..I'll look around for you to see if there's any places like that around here...
Shit will ride the fuck out when it's done..lol...
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
PM me I'll meet up with you and give you a hand getting the thing running I have already done the swap several times. I'll also help you come up with a good fuel line setup for cheap that wont give you any problems.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
