how to check engine codes obd1 crx ???
just need 2 kno how 2 check the engine codes for an obd 1 in a crx
lmk
- Josh
lmk
- Josh
figure out where on the ecu the obd-1 jumper is suposed to go and jump those wires. where do they go? i have no idea
"Black people can't be racist" - Some black guy.
OBD1 Honda ECU pinouts - Honda Forum / Acura Forum - SuperHonda.com
this says it pin D4. since it has voltage i would assume you ground it to get the light to blink
i know about the paper clip jumper under the pass side dash in the obd 1 tegs ect, but not the obd1 crxs
thanx freak!
thanx freak!
Sometimes A-Zone and Advance will check codes for free.-Bob
thats tru but i have a diagnostics scanner .. and if you got a motor with a different ecu than whats actually supposed to run it like a p28 chipped than it wont even link up .. so your best bet it to ground d4 and count the blinks and look up how many blinks is what .. and i believe auto zone does it for free no matter what i used to work there so ..
