Help With Crx Electical Problem
Old Apr 3, 2009 | 04:44 PM
JAVIELITO's Avatar
Default Help With Crx Electical Problem
OK so last night i blew a fuse for my tail lights and parklights, i replaced it and today same shit happened . can someone please help me
Originally Posted by JAVIELITO
to the grammar police of TR ... I DON'T GIVE A FUCK WHAT YOU THINK ABOUT THE WAY I SPELL
im sure i spelled that right for you all to understand.
Old Apr 3, 2009 | 05:38 PM
rangcrx's Avatar
engine building &best
check your radio that fuse is also part of the radio wireing make sure no wires are touching ground
i love AUTOZONE
Old Apr 3, 2009 | 07:37 PM
95gainfla's Avatar
smokes weed...everyday.
you blew a fuse for a reason. just replacing it usually doesnt fix it. find out what caused it to fail(usually a short in the circuit)
I <3 RooR!!!!!!
Old Apr 3, 2009 | 07:49 PM
Remove all bulbs that are on the fuse. Replace them one by one.
When the fuse blows again, you will have found the problem.
Might be something simple like a bulb base shorting out to ground.-Bob
Old Apr 4, 2009 | 06:42 AM
SEEKERone's Avatar
Trialed for Treason
most common cause is (as mentioned) an aftermarket radio harness short
Usually the wire in the harness is orange or orange with a white stripe.
most aftermarket radios don't use this wire and if not taped up will short to any bare metal.
Liar, you couldn't cut me deeper with a knife if you tried
Old Apr 4, 2009 | 08:30 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
^ True... But check ur grounds too..
Old Apr 4, 2009 | 08:39 AM
JAVIELITO's Avatar
Ok I Think I Fixed It I Just Came Back Inside .... I Had Two Wires From My Corner Lights Touching So I Taped Them With Electrical Tape And It Seeems To Be Doing Fine
Old Apr 4, 2009 | 08:43 AM
there was ur short ur straight!...
