50 shot?
TR Balla Donor Supreme
on
i have whats pretty much a stock 95 dx(with no cat and all the crap removed from my airbox) and i was wondering if a 50 shot would hurt anything... used wisely of course. my roommate has a bottle and the kit and hes going to give it to me if i want it so i was just checking to see if it would do more harm than good.
as long as it is used corectly it should be fine if it is your first
time with nittros you might want to do some reserch on the
correct way to use it its not the best thing for your engine but
can give you that winning edge that a DX needs but be
careful you can blow the shit out of your motor if left on to
long....so I hope you do the reserch and it helps
art
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
www.rccustomz.com
Guest
Posts: n/a
175 b33|\| d0|\|3 pl3|\|7y 0f 71m35. 7h3 0|\|3 m4j0|2 7h1|\|g 7h47 bl0\^/5 7h3m up 15 5qu33z1|\|g 0|\| 70p 3|\|d (70p 0f 47h 4|\|d 57h g34|2). Y0u|2 m070|2 \^/1ll 74k3 4|\| 0cc4510|\|4l b3471|\|g bu7 d0|\|7 7|2y 70 70p 0u7 7h3 c4|2 \^/17h 7h3 b077l3 0|\|.
Guest
Posts: n/a
a 50 doesent hurt that bad if you really want to upgrade the things you have to worry about is fuel and piston rings. the thing with big shots is the rings can go and the eather you have too much friction on the piston wich causes it to melt/warp or oil blow by to the cumbustion chamber wich the hot oil will cause detonation and literlly fuxor your motor. and fuel is the same way as the detonation.
*Nitrous master steps in*
50 shot in fine maybe look at some b18c/h22a injectors and a regulator like the b&m if you want to be a little safer. The number one killer from nitrous is valves and rings. also dont spray below 3200 rpms. if you need help with any installation hit me up ive installed a shit load of kits from NOS to Zex to Venom.
http://www.floridaracing.org
wonderful when?
