Integra (95 Coupe) Seats into Civic (96 LX 4 Dr) I AM STUCK
Old Mar 23, 2009 | 05:00 PM
bryan's Avatar
do not touch mine
Question Integra (95 Coupe) Seats into Civic (96 LX 4 Dr) I AM STUCK
FUCK.
I am having trouble installing my Integra seats into my Civic. I am currently working on the driver's side and I am only able to get 3 bolts lined up. I replaced the entire bracket on the right side (passenger) of the integra driver's seat with the civic bracket and that is fine..On the left side of the driver's seat I replaced just the sliding portion of the bracket (with the two bracket tabs) and it will not line up correctly. The front left bracket hole is off by about half an inch to the left. I did not replace the entire bracket on this side because it has the reclining coil and other parts on it that looked complicated..Do I have to replace that entire bracket in order for this to line up?
So, In short..I have Integra Driver's Seat with Full Right Side bracketing (excluding the part that goes up into the side of the seat) and on the Left Side I have just the Sliding portion of the bracket (with the bracket hole tabs) The problem is this left side bracket will not line up (front left hole)
HELP
Old Mar 24, 2009 | 01:38 AM
The Spectacle's Avatar
Spent more money than you
I did this swap a while ago and just left it bolted down with 3 holes.
You would probably need to fab up a bracket to bridge the gap between the hole and the rail.
Racing Integration
LHT Performance
My tuner is named Alpha
Old Mar 24, 2009 | 04:08 PM
bryan's Avatar
do not touch mine
Figured it out..Got all 4 bolts in on both sides
Driver side solution: Complete Civic railing on right side (includes civic seat belt buckle), Left side I left the Integra seat rails intact..Bolted in perfectly.
Passenger Side solution: Civic complete railing on seat buckle side, On left side (reclining side) I just replaced the slide part of the railing with civic slide and left the rest of the Integra bracketing in place..Bolted in perfect..Had to push it down a little but it works..All 4 bolts in!!
Old Apr 3, 2009 | 09:25 PM
Thanks for figuring out and posting up the solution for all of us.
Rep for you.-Bob
Old Apr 5, 2009 | 04:55 AM
Skunkedb16A2's Avatar
Rep'd!
