weird ek problem x2
Old Mar 22, 2009 | 08:03 PM
yoshi06's Avatar
Default weird ek problem x2
first off the car is 96 dx and its always been 5 speed
i bought it as a shell and put a rebuilt d15b7 obd1
i used the y7 dizzy and an auto y8 mani with obd2 injectors and alternator
im getting a few codes
code 14-IAC Valve (Idle Air Control)
code 20-Electrical Load Detector
code 41-Primary Oxygen Sensor - Heater
at the last one that is fukin with my head
code 74-cylinder 4 misfire
i switched parts from a running car and still nothing
i have two dizzy and before i pulled the plug to see if it was arcing and i got nothing now this new dizzy makes the cylinder arc im getting fuel to all cylinders and i replaced the iacv and the code went away but now its back
everytime i did or replaced a part i restarted the ecu and unpluged the battery
im gettin a rev up and down like its surging i dont have the secondary o2 sensor hooked up yet but someone help me thanks
Old Mar 22, 2009 | 08:22 PM
mtber's Avatar
Use the factory helms manual to resolve all of your codes. If you can't figure it out take the vehicle to an experience honda shop.
Old Mar 22, 2009 | 09:05 PM
marktopia's Avatar
TR Balla Donor Supreme
try another ecu? make sure all vac lines are hooked up ans you have your map sensor hooked up correctly
Old Mar 22, 2009 | 10:22 PM
yoshi06's Avatar
have three other ecus all the same problems
Old Mar 23, 2009 | 12:32 PM
yoshi06's Avatar
Old Mar 23, 2009 | 06:41 PM
yoshi06's Avatar
Old Mar 23, 2009 | 06:42 PM
mtber's Avatar
You have too many issues with your vehicle to have some one remotely diagnose. Have the car inspected in person.
Old Mar 24, 2009 | 12:26 PM
yoshi06's Avatar
i only posted because its an obd1 motor in a obd2 car its just wierd to me that even the parts off a running car stil cause the problem and i want people to post their opinion not for one person to basically constantly tell me give up and pay out my asshole
Old Mar 25, 2009 | 04:04 PM
yoshi06's Avatar
Old Mar 25, 2009 | 04:22 PM
hondachris1994's Avatar
hatchback1994
Check and see if your getting spark in cylinder #4, change the IACV(they only throw a code if they are bad) try another O2 sensor. If u have tried, then u have electrical issues possibly sensors ran to the ecu wrong
