integra gsr idle problem
Old Mar 21, 2009 | 12:30 PM
SilentKrnSoulJah's Avatar
(> '.')> V.I.P <('.' <)
Default integra gsr idle problem
my friend has a problem with his 01 integra gsr with JDM B18C.
car ran fine but few weeks ago his crank pulley got loose and had to re tighten up after that it start acting up.
every time when he drives, RPM stays high around 1700 and stays there for awhile then drops it down but when u press cluth, it jumps back up and stays high rpm again. it also sputters too. its weirdddd lol
we checked all the vacum lines and also clean up IACV, change out the map sensor, new spark and wires, new disturbitor.
i think its timing is off but im not too sure about it.
any help would be greatly appreciate it!
Old Mar 21, 2009 | 12:58 PM
hondachris1994's Avatar
hatchback1994
What pulley got loose? Any CEL?
Old Mar 21, 2009 | 01:02 PM
crank pulley and whats CEL? check engine light? if so then no....
Old Mar 21, 2009 | 01:48 PM
hatchback1994
What do u mean crank pulley got loose? Did the bolt on the crank pulley start getting loose or did the tensioner bolt come loose?
Old Mar 21, 2009 | 01:52 PM
bolt on the crank pulley got loose and belt started slapping so we had to re tighten them up.
Old Mar 21, 2009 | 02:30 PM
hatchback1994
then yes its very possible u jumped a tooth on timing
Old Mar 21, 2009 | 02:42 PM
i knew it! i will re do the timing tomorrw and will see what happen.
thanks for your info! i appreciate it
