fuel injector and distributor question
Old Dec 30, 2001 | 06:56 PM
93sircivic's Avatar
I need to know if the 2000 itr injectors will work with a 92-95 wiring harness(do the injectors have a different plug than the 92-95 wiring) How can I make It work?
How can I make a 2000 itr distributor work with the 92-95 wiring using a p28 for the ecu?
late
Old Dec 30, 2001 | 10:35 PM
RONIN's Avatar
Tetris on a stick
Originally posted by "Someone"
Originally posted by hybridEG
they will work they just have different plugs foem the wiring harness. they are both satureted injectors.
yeah you are putting obd2 injectors on an obd1 wiring. call rc they can send you some new clips that youll have to spilce on for about $8 each i think.
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Dec 31, 2001 | 10:03 AM
RONIN's Avatar
Tetris on a stick
wait a sec i think i got that completely fukking backwards. you will have to get obd2 clips to splice in. i dont think rc has those. check with honda or maybe someone here is putting new injectors on their 96+ and will be cutting their ols clips off.
Old Jan 1, 2002 | 08:08 PM
93sircivic's Avatar
I ended up getting the whole engine wiring harness I think I can just plug it all in and be good to go? btw its going into a 93 si.
Old Jan 1, 2002 | 10:39 PM
KJ's Avatar
KJ
bored at work
The distributors do not have all the same wires. The crank angle sensor is located on the oil pump in obd2. You can just plug the obd2 harness into the obd1 car. No need to change the injector plugs or anything like that. Just wire in the secondary butterflies knock sensor and the evap(if you want).
Old Jan 2, 2002 | 06:50 PM
93sircivic's Avatar
Im using a p28 ecu ? Also type rs dont have secondary butterfies and the p28 doesnt see the knock sensor
Old Jan 2, 2002 | 08:19 PM
KJ's Avatar
KJ
bored at work
Right I misread. Wow you really dont have anything to worry about then.
WhiTE RICE
Dec 28, 2011 06:53 AM
gsx eclipse
Jul 23, 2006 08:19 AM
sihatch
Mar 16, 2001 09:37 PM
boostoplentyz28
Nissan/Infiniti Tech
5
Mar 8, 2001 05:07 PM
Bill
Mar 8, 2001 05:02 PM
