I need single cam help plzz
Old Mar 17, 2009 | 08:38 AM
Datjdmkidek9's Avatar
Exclamation I need single cam help plzz
I had bought a d16y8. Block but the block had a y7 head on it
The block look perfect I replaced all seals and gaskets and with
A brand new head gasket threw the head on to spec but the
Car was running fine but last night I started to burn coolant
I think the head gasket went orits sucking it in threw the intake mani
But that's shit was burning it and over heating
Need help asap and is this combination possible
Old Mar 17, 2009 | 09:30 AM
hondachris1994's Avatar
hatchback1994
R u sure its sucking it threw the intake mani? The only coolnt line that goes to the intake mani is the 1 for the IACV. There are 2 lines that go 2 the IACV. 1 is vaccuum and the other is a coolant line u may have them backwards but if the car was running fine before then u did have them right. Now if u did blow the headgasket, coolant would get into the combustion chamber and thats y u smeel coolant burning
Old Mar 17, 2009 | 09:47 AM
Default re
That's what I thought I blew the head gasket but it was brand new
And I torqued it to spec but I guess it was a cheap head gasket, but that swap is possible rite
Old Mar 17, 2009 | 10:07 AM
hatchback1994
^^^yes
Old Mar 17, 2009 | 10:10 AM
hatchback1994
before u installed the headgasket, did u make sure the head and block were straight? The head may need to b milled to ensure straightness
Old Mar 17, 2009 | 11:07 AM
na I thought it would have been ok but I guess not, when I remove it I am going to check it and take it to get shaved or just maybe
Resurfeced
