1994 acura integra Idle Problem
Old Mar 14, 2009 | 07:17 PM
PasswordDC2's Avatar
TTT
lol the distributor wires and plugs and cap and map sensor brandnew.. Check Engine light 5 .
Old Mar 14, 2009 | 07:47 PM
Thatguysstuff's Avatar
Hey its that guy!!
5 MAP - manifold absolute pressure sensor
maybe you switched the map and the tps plug..
Old Mar 14, 2009 | 08:49 PM
medicmatt's Avatar
my mojo so dope
just noticed ^^ is a mod.....how the hell did that happen? i should be a mod....vote for me!!!
Old Mar 14, 2009 | 08:54 PM
Nandosol's Avatar
Garage Slut
why is there like 5 people named matt in this thread. All of you should go and start your own forum or some shit. Mattracing.com or something.
That mod must be drunk, they all like to fuck with us when their all inebriated.
Stop drunk typing damn it!
Old Mar 15, 2009 | 05:58 AM
hondachris1994's Avatar
hatchback1994
then he would b throeing a code for TPS cause of the different voltage each sensor takes. I had this same problem before and one ofthe wires that went to the map sensor plug was loose. Try wiggling the wires on the map sensor while the car is running and see if the idle fluctuates at all. Also the MAP sensor has 3 wires goin to it and the TPS has 2
Old Mar 15, 2009 | 06:25 AM
ill see if thats what it is . once sec.
Old Mar 15, 2009 | 07:53 AM
  #17 (permalink)
slicshoes's Avatar
sorry bro the tps has THREE wires going to it and the map has THREE also
get a volt meter and when u put the tps on ground the black tester and put the red one to the Middle wire for the tps it should b a red wire/blue line the when it is in the correct position the volt meter should read 0.45 volts good luck i juat went tru all this and my car is still doing the same thing
5TH GEN. CIVIC CREW MEMBER #26
:eg coupe b20z/gsr trans
Old Mar 15, 2009 | 08:24 AM
  #18 (permalink)
