need crankshaft help
Old Mar 7, 2009 | 01:51 PM
markstheman365's Avatar
cant slide
Default need crankshaft help
my crankshaft went bad,
the part were the key sit broke so i need a new crank
anyone know how to do it or a good place to get it done at
contact admin@tamparacing.com to advertise on here.. - mod
Old Mar 7, 2009 | 02:00 PM
StreetBlitz's Avatar
B Tuned CRX
If you just want to replace the crank and everything else is OK, then it shouldnt be a problem. Just drop the tranny, take off the tensioner, lower the timing side mount, take off oil pan, desconnect rods and push them to top of head, take off the oil pump, and rear seal mount, drop crank and throw it in neighbors yard, install new main bearings std., put oil pump back on, rear main mount back on, install rods w/ new std. bearings, install new thrust bearings, put std. main bearings on main caps, tighten the caps / oil pick up... the ovious stuff to get it on the road.
Old Mar 7, 2009 | 07:44 PM
cant slide
lol you wanna do that for me, ill pay
Old Mar 7, 2009 | 08:22 PM
rangcrx's Avatar
engine building &best
did it only brake where the pulley goes or did it brake all the way to the timing gear?if only where the pulley goes what you can do it use a dremel and cut out another section oppisite side to fit a new key,as long as the motor is timed correct then it will not be a issue.then you dont need to take the motor apart
i love AUTOZONE
Old Mar 8, 2009 | 12:38 AM
B Tuned CRX
get the bearings, crank, n gaskets. i'll do it.
Old Mar 8, 2009 | 06:47 AM
sprjit22's Avatar
Rick James bitch
Yeah that will work but, if you ever pull the head make sure the person setting the timing knows. I ran a crank pulley missing the key and I set the timing checked it and I was off by a tooth so I did it again after about the 3rd time I was like wtf and found the key was missing and allowing the pulley to move just slightly.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Mar 8, 2009 | 11:21 AM
B Tuned CRX
^ this guy actually has a lift, it could make things allot easier...
727-768-9917
Old Mar 8, 2009 | 12:43 PM
sprjit22's Avatar
Rick James bitch
lol I see I have help for sure. lol
thanks
T & C Racing
FT Crew Mascot lol
Old Mar 8, 2009 | 12:47 PM
klept0's Avatar
resident klept0
Terry will hook ya up on the work - I def vouch for homie...hes gonna be doin some work on my ride soon...so hit him up
Car History:
92 Dodge Spirit - sold!
98 Civic EX - bank raped me on that one
87 Civic DX - sold!
95 DC Integra - sold!
96 Civic EX - sold!
05 Acura TL - current
Old Mar 8, 2009 | 03:26 PM
cant slide
well im actually gonna try what rangcrx said
i jus need a new pulley first
