acura clutch problem
Old Mar 4, 2009 | 01:41 PM
redcoats1976's Avatar
Default acura clutch problem
my son in law has a 97 integra with 130,000 miles on it.just recently his cluch is not working correctly.he says its sometimes hard to shift.one shop wants to replace the clutch,resurface the flywheel,and replace the clutch slave cylinder.im thinking replace the slave cylinder first and see if that fixes it...other opinions?
Old Mar 4, 2009 | 01:55 PM
DemonCivic's Avatar
when the car shifts hard, try pumping the pedal....if it then shifts easy you need a slave
Old Mar 4, 2009 | 01:57 PM
StreetBlitz's Avatar
B Tuned CRX
well if since you stated miles, im guessing the clutch is pretty old. I'd drop the transmission and just replace the clutch and sand the flywheel. take about 4 hours taking your time.
Old Mar 4, 2009 | 01:58 PM
wolfenr1984's Avatar
Great White Hope
Replace the slave cylinder, remove all old fluid, and bleed off the system. I would also recommend that you get the transmission fluid changed and either replace it with 10w-40 Mobil 1 or Honda MTF.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Mar 4, 2009 | 02:44 PM
boostedcoupe's Avatar
just replace the clutch. its time, not that big of a deal
Old Mar 4, 2009 | 03:41 PM
Thatguysstuff's Avatar
Hey its that guy!!
its not a red GSR with a black hood and yellow high beams is it????
Old Mar 5, 2009 | 11:46 AM
no
