h23 oil leak
Old Feb 27, 2009 | 02:22 PM
Prelude_!n_7h3_D!r7's Avatar
Default h23 oil leak
just rebuilt my engine with all new seals (including oil pan) head gasket oil pump, and water pump. its still leaking, slow, but still leaking. any ideas whats going on
Old Feb 27, 2009 | 02:23 PM
wolfenr1984's Avatar
Great White Hope
cam seals? where is it leaking from?
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Feb 27, 2009 | 02:24 PM
cam seals were replaced. some where on the left side of the engine
Old Feb 27, 2009 | 02:26 PM
Great White Hope
distributor o-ring? do those motors have a cam cap like the b-series motors?
Old Feb 27, 2009 | 02:27 PM
yup but thats the other side of the engine
Old Feb 27, 2009 | 02:33 PM
Great White Hope
gotcha. did you replace the crank seal? can you not see the leak anywhere?
Old Feb 27, 2009 | 02:38 PM
last week. its dripping from the back right corner of the engine
Old Feb 27, 2009 | 02:40 PM
Great White Hope
is your filter tight? did you use any sealant on the VC gasket?
Old Feb 27, 2009 | 02:49 PM
boostedcoupe's Avatar
if its coming from the corner, it could be where the oil port is in the head. i know on the b series, the head gaskets leak from there. common problem
more info on where its coming from? head to block? valve cover to head?
Old Feb 27, 2009 | 03:05 PM
jlude90's Avatar
aspiring luder
find out where its leaking from, i could guess at every seal you have but that won't really help
