i got a question need help ..
i got a honda motor that my uncle had with a bunch of his junk motors but the honda motor is good but heres the deal ... its says its a d16a .. but ive never heard of it its a dohc motor and it says d16a .. valve cover looks like a ls vavle cover
yeah thats JDM y0! haha look it up on google.. Im sure you will find lots of info on it.
D16A1
- Found in:
- 1986-89 Acura Integra (USA)
- Displacement : 1,590 cc (97 cu in)
- Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
- Valvetrain : DOHC
- Fuel Control : OBD-0 MPFI
- 1986-1987
- Compression : 9.3:1
- Power : 113 hp (84 kW) @ 6250 rpm
- Torque : 99 ft·lbf (134 N·m) @ 5500 rpm
- Piston Code: PG6
- 1988-1989
- Compression : 9.5: 1
- Power : 118 hp (88 kW) @ 6250 rpm
- Torque: 101 ft·lbf (137 N·m) @ 5500 rpm
- Piston Code: P29 (Equivalent to PM7)
yeah he said it was an A1 not just a D16A.. the A1 is USDM the D16A is the JDM but its also known as the ZC.. or at least thats what I just read.. haha wanna be sure my shits right first.
