wheel bearing is bad?
Old Feb 26, 2009 | 11:15 AM
FrodoGT's Avatar
Found the Vtec switch.
Its the wheel bearing if the rotor moves INSIDE and separate from the caliper. I went through this on my car on two different knuckles before I finally broke down and bought a new bearing.
TR Old Skool EF Crew #24
Old Feb 26, 2009 | 12:13 PM
Thatguysstuff's Avatar
Hey its that guy!!
you need to get it pressed out and a new one pressed in...
Do you have a whomp whomp noise when driving??
Old Feb 26, 2009 | 12:29 PM
rangcrx's Avatar
engine building &best
you can hammer them in and out also its pretty easy.the harder part is like your old one cause the inner case gets stuck on the hub shaft you have to use a 12" wrech and a hammer to knock it down.you will also need needle nose prlyers to remove the large lockClip
i love AUTOZONE
Old Feb 26, 2009 | 03:00 PM
rollinondonuts's Avatar
Love all.
pictures always help so much im a visual learner ,Thankyou man.Well i wouldent be able to describe the noise as a whomp whomp but as i go around turns i can hear it sounds like shizzzzorscrapppppppppppp,,Naa it sounds like metal on metal rubbing in a rotation manor..And now my passenger is making kinda the same sound but i think its just the disc
If ANYONE NEEDS ANYTHING TOWED / MOVED IN THE TAMPA AREA PM ME ,ROLLBACK ON THE READY CHEAP!
Old Feb 26, 2009 | 03:02 PM
Love all.
I do belive thats exactly the way it wiggles but im going to take the wheel off later tonight if i can get a jack
Old Feb 26, 2009 | 03:22 PM
rangcrx's Avatar
Shot at 2009-02-26
i love AUTOZONE
Old Mar 1, 2009 | 01:35 PM
  #17 (permalink)
Love all.
So i drove the car today to a friends close by and i hit a railroad track and the wheel gave way .I put a bearing on order at napa they dident have one in stock I about got the hub off im waiting for my friend to get off work so i can borrow a 17mm wrench
Old Mar 1, 2009 | 01:48 PM
  #18 (permalink)
rangcrx's Avatar
should have went to autozone they always have them in stock 510030
i love AUTOZONE
Old Mar 1, 2009 | 06:13 PM
  #19 (permalink)
Love all.
They would have to get one from lakeland first place i called
Old Mar 1, 2009 | 06:35 PM
  #20 (permalink)
wolfenr1984's Avatar
Great White Hope
Dude, go to Carquest next time, if there's a next time, and get an oem one through Carquest's sister company, Worldpac. If you know someone who works there, you could get oem parts cheaper than the dealerships can sometimes. Ask for Worldpac by name or else they won't look there. And if they don't know how to use Worldpac, pm me.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
