B series Timimg Belt help
Old Feb 23, 2009 | 04:00 PM
Civic si121's Avatar
Default B series Timimg Belt help
I took off my head to change my gasket and i marked the cams and the belt but now i cant really see the marks but can see a lil... i have everything in but dont know how the belt goes back in the cams if anyone can tell me what i have to do PLEASE...someone that knows what they are talking about or doing...
Old Feb 23, 2009 | 04:19 PM
94jdmeg6civic's Avatar
take out the cams out the buttom end at tdc and put the cams back in at tdc and your done !!
Old Feb 23, 2009 | 04:54 PM
i mite sound dumb but what is a tdc? or where is it?
Old Feb 23, 2009 | 05:21 PM
TurboJdmEk's Avatar
is on blocks...
top dead center, it is when the #1 piston is at the top of the intake stroke, or exhaust i am not sure. i have a haynes manual i suggest you get one. g/l.
its coming...
Old Feb 23, 2009 | 05:56 PM
YARO's Avatar
Smith & Wesson Protected.
You should def. NOT be doing this If you don't even know how to time your engine. Did you torque everything down to Spec and in Steps??
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Feb 23, 2009 | 06:06 PM
yea i talked to a machanic here and told me what pattern to torque it beacuse he worked in alot of hondas...and i dont know how to time my car but i did mark it...
wolfenr1984's Avatar
Great White Hope
the head determines which stroke it is, intake or exhaust, not the block alone.
First, as long as the number one cylinder is fully extended and can't move anymore up, and as long as it isn't starting to go down, you should see a mark on your crank pulley that lines up with a pointer on the plastic timing chain cover. Second, line up your cam pulleys, it looks like they are aftermarket. They should have cam with instructions on how to line them up. If not, they may have an indication of what is up. Make sure that they point directly up (90 degrees) from the top of the head (aka, the valve cover mating surface). After you have made sure that all of those marks are lined up perfectly, you can then stretch the belt over the intake cam, then over the exhaust cam, and behind the tensioner.
Here's a picture. Don't mind what is typed on the picture, just look at the gears.
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Feb 23, 2009 | 06:59 PM
hondachris1994's Avatar
hatchback1994
Spin the crank pulley untill u see 3 lil lines after the three single lines u will see 1 lil line by it self, line that lil line with the arrow on the lower timing belt cover and that is TDC then all u have to do is rotate the camshafts as stated above then put your timing belt on, rotate the engine by hand three complete rotations then line that single mark back on the crank pulley to the arrow on the timing belt cover. If your cams are facing up and in and u have the crank pulley rt on that mark, then all u hae to do is loosen the tensioner pulley bolt rotate the motor three teeth then tighten the tensioner pulley bolt and your done. Hope this helps
Old Feb 23, 2009 | 07:29 PM
Red2GDSM's Avatar
In the making...
damn is everyone having problems with the heads on their cars now? Im doing this too but I only have one cam to worry about =[
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Feb 23, 2009 | 07:37 PM
this sounds like a painfull job to do....and i know if u dont do it just right my motor can mess up and i deff dont want that....
