LS Turbo
Old Feb 17, 2009 | 04:21 AM
jboyzTeg's Avatar
Default LS Turbo
so usually I go all motor but my new project is going LS Turbo and I've never delt with going turbo. Any advice anyone ? Any recommendations ? Is it true you can go stock LS Turbo ? And if I decide to build the motor also what would be good to do to it so it would work better with turbo. Thnx in advance !
Old Feb 17, 2009 | 05:32 AM
jboyzTeg's Avatar
bump anyone !
Old Feb 17, 2009 | 06:14 AM
Bori300's Avatar
Bori300
yes its tru you can go turbo on stock internals.. but if i were you i would do a compression and leak down test to check to see if your engine is healthy enough to hold boost..
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
