Smoke problem....Help..
Old Feb 10, 2009 | 04:20 PM
Civic si121's Avatar
Default Smoke problem....Help..
I was wondering is anyone can help me out....I have a GSR motor and im getting white smoke...the only time it smokes white when i step on it...but when im driving it dont..idk what it could be just happens when i step on it all the way..if anyone can help i know im leaking oil from the head because i see oil coming out right above where it says B18..im getting that replaced but idk if thats the problem...thanks
Old Feb 10, 2009 | 05:11 PM
int9gsr2's Avatar
check the head gasket...
I Think it's my Flux Capacitor? U/C 99LS-T
Old Feb 10, 2009 | 05:52 PM
DemonCivic's Avatar
you need a cylinder leak down test performed. it can isolate where your problem is.
Old Feb 10, 2009 | 06:16 PM
Skee's Avatar
valve seals ftw lol
Custom high amp Alternators.. pm me
Old Feb 10, 2009 | 06:37 PM
so a leak down test will tell me what the problem is?
Old Feb 11, 2009 | 05:23 AM
sprjit22's Avatar
Rick James bitch
Leak down tells you where the leak is if it is in the head gaskett, head, or rings then you know where the problem is. Also verigy that it is white, blue or black smoke.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Feb 11, 2009 | 09:27 AM
boostedcoupe's Avatar
if the smoke is white, thats bad, that coolant in you combustion chambers. since you said that the motor is leaking oil from the head gasket, it could also be allowing coolant to seep into cylinder #4. check your coolant and see if it has dropped. either way you want to replace that head gasket right away to avoid anymore damage to your motor.
also the leakdown test will isolate the leak
Old Feb 11, 2009 | 09:47 AM
HonkeyDong's Avatar
Every dog has his day.
Originally Posted by Skee
valve seals ftw lol
white smoke(aka coolant) out of valve seals? wtf m8
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Feb 11, 2009 | 11:28 AM
ok guys thanks for the help...i guess i have some work to do to the motor...ill prob have to bring the head to the machine shop i guess
Old Feb 11, 2009 | 12:37 PM
Skee's Avatar
?? wtf m8 what is that?
and said when he gets on it if it where head gasket it would do it all the time
