Will rebuilding the engine boost comp?
Old Feb 9, 2009 | 03:04 PM
Prelude_!n_7h3_D!r7's Avatar
Default Will rebuilding the engine boost comp?
Will rebuilding a H23 boost compression?
Old Feb 9, 2009 | 06:19 PM
SmokinS13SR20's Avatar
That ginger...
Compression, yes...
Compression ratio, no...
Old Feb 9, 2009 | 10:03 PM
MightyMaxGS-T's Avatar
what's your real issue bro? lol i can see a hidden question or problem in there....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Feb 9, 2009 | 11:53 PM
The heads were also cut twice. would that affect anything?
no real problem just had it rebuilt and the compression is high so it blew out a bunch of engine gaskets and its bleeding oil like crazy.
before it started leaking it was fricking crazy fast with like 12% throttle.
but the gaskets are 13 y/o so i guess its not that bad for rubber parts. is there anything else I should watch for?
Old Feb 10, 2009 | 10:02 AM
That ginger...
How much did the head have shaved off in total?
Shaving the head will raise the compression ratio...
The only gasket that should actually see the higher compression is the head gasket.
depending on how high the CR is now, you may have to run some higher octane fuel.
Old Feb 10, 2009 | 10:14 AM
i already run premium only
Old Feb 10, 2009 | 10:34 AM
Nandosol's Avatar
Garage Slut
Old Feb 10, 2009 | 10:50 AM
sleepinsol's Avatar
starting over
when motors are rebuilt generally the heads are slightly milled and the blocks are slightly decked. so yes the cr will go up as will the psi when u do a comp test.
Old Feb 11, 2009 | 08:56 AM
just found out that my oil pump is bad. do you think swapping it with one out of my spare block would be bad?
