Cabin air filter
Old Feb 6, 2009 | 02:51 PM
Pony 5.0's Avatar
Default Cabin air filter
Does anyone know how to change the cabin filter for a 2000 Honda acccord?
1990 Mustang GT, Holley Systemax, GT40X, B-cam, 24lbs injectors, Pro-M 80mm, 70mm PP TB, BBK LT w/X-pipe, Magnaflow catbacks, Baer, Eibach, Tokico, Walbro 255lph, UPR subs/uppers/lowers, 31 spline Mosers
Old Feb 6, 2009 | 03:23 PM
Steve-O's Avatar
Fiat Specialist
if i remember its behind the glove box and there will be a plastic door that pops out and there is 2 small cabin air filters that sit side by side
EZ to get to just empty ur glove box when doing it lol
1990 Honda Civic DX Hatchback - SOLD
2006 Scion tC - Traded
2013 Fiat 500 Abarth - Current DD
Old Feb 6, 2009 | 08:34 PM
343whpDelSol*'s Avatar
close, thats the new body styles. the 2000 body style...here ya go:
open the passanger side door, remove the dash side cover, theres a gold screw or two that go into the plastic part of the dash by the passanger knees. Then go to the center consol pocket, under the radio, and you can reach to the back of that pocket and pull the small piece of plastic out that is the top/back of that pocket. There will be a screw on each side behind there...naturally remove the passanger side one. Youll then be able to drop that passanger side part of the lower dash. watch though because those clips tend to pull out of the plastic when your pulling.
Remove the 2 black screws in the glovebox next to the lock, then remove the 2 covers (one on each side of the glovebox) and the two screws behind those covers.
Next remove the 3 or 4 gold screws in the metal strap that is behind the plastic knee plate you removed. Then you'll be able to pop the glovebox out (be careful not to break the glove box light switch on the driver side of the glove box while removing and reinstalling the glove box). Next youll be able to remove the metal plate with a screw on each side of it. theres a vertical door behind there that you unclip. Theres two white/clear plastic pieces that hold the filters.
It sounds difficult, but if you follow this and once you get in there...its only about a 10 min. job. Good luck!
98 Eddie Bauer Explorer with single 12W7: 7th loudest vehicle in PA: Sold
93 Gutted Greddy Turbo and Zex Nitrous EG Hatch: Sold
07 Caliber with 13W7 and 20's: Traded
08 Ridgeline with all JL system: Traded
94 343whp D16z6 Del Sol: Sold
04 VW R32: Doin' Thangz
Old Feb 7, 2009 | 05:52 PM
Pony 5.0's Avatar
Thank you guys. 343, thank you for the detailed directions.
Old Feb 7, 2009 | 06:28 PM
freakasis's Avatar
BAM!!!!!
How-to Change 6th Gen Cabin Air Filters - AccordRacing.com
"Black people can't be racist" - Some black guy.
Old Feb 8, 2009 | 10:52 AM
No problem man...and for anyone with a newer style accord, they do come out like that, but they're only a single filter. CRV's have the horizontal dual filters up until the current body style which then switches to the same single filters as the 7th gen and up accords....completely irrelevant information to this page...but just figured I'd add it in to anyone with a newer accord looking at this
