fuel pump help
Old Feb 3, 2009 | 03:54 PM
fanatic22's Avatar
deebeetoo
Default fuel pump help
okay tr when ever i press the gas on my car it idles down and the car shuts off.... now i need to know it its the fuel pump?i changed the fuel filter and was working good then all of a sudden today it did it again... help how do it fix the fuel pump in the gas tank am i right...?
Old Feb 3, 2009 | 03:56 PM
Thatguysstuff's Avatar
Hey its that guy!!
car???
maybe bad fuel pressure regulator???
maybe bad plugs???
thats what was wrong with my poor mans type R...
Sputtering when trying to get going....
Old Feb 3, 2009 | 04:03 PM
freakasis's Avatar
cold be alot of things. but the fact that it stopped and came back means its one of these:
fuel pump
tps
map
wiring
you can test the tps without removing it so start there. if its good check the fuel pressure. map sensors are everywhere at the junkyard, get 3 or 4, if none of them solve it then its prolly the wiring. and yes the fuel pump is in the tank, how you access it depends on the car and the year.
"Black people can't be racist" - Some black guy.
Old Feb 3, 2009 | 04:44 PM
fanatic22's Avatar
deebeetoo
atm i gues sim going to check the dizzy and the spark plugs and the wires...
Old Feb 3, 2009 | 04:49 PM
fanatic22's Avatar
deebeetoo
idk i was just driving it and it seemed fine doesnt the fuel work or not work ???
Old Feb 3, 2009 | 05:18 PM
fanatic22's Avatar
deebeetoo
Old Feb 3, 2009 | 05:28 PM
sirmichaelthe3's Avatar
what car and is it stock or swap
Old Feb 3, 2009 | 05:46 PM
fanatic22's Avatar
deebeetoo
no its a b17 original
Old Feb 4, 2009 | 03:33 PM
DemonCivic's Avatar
do you have the check engine light on?
start there
if not, check the fuel pressure like stated above.
good luck
Old Feb 4, 2009 | 08:41 PM
fanatic22's Avatar
deebeetoo
no cel and thank you ^^^^ bump
