What ECU do I need to get ?
Old Feb 2, 2009 | 01:41 PM
xsh0rtyduw0px's Avatar
Dell Funds my hobbies
Thumbs down What ECU do I need to get ?
trying to put B18b1 in ek what ECU will I need to get and how can I tell if its OBD2A or OBD2B also car is Manual and motor is a 96+ Ls..any help appreciated thanks
Old Feb 2, 2009 | 02:16 PM
mtber's Avatar
What year/make/model is the vehicle you are putting the motor into ?
Old Feb 2, 2009 | 02:23 PM
96 cx hatch stock motor is d16y7
Old Feb 2, 2009 | 02:29 PM
mtber's Avatar
You will need to keep the stock 96 civic engine harness & modify it for your ls swap. You will need to modify your idle air control valve plug from a 3 wire plug to a 2 wire plug & re-pin the iacv at the ecu harness also.
You will need to extend some wires such as injector wires etc...
You can run any obd2a p75 integra ecu from a 96-99 integra.
You will also be able to run an obd2a to obd1 jumper and run a chipped obd1 engine computer.
Old Feb 2, 2009 | 02:45 PM
thanks for the quick response much appreciated
Old Feb 5, 2009 | 06:16 AM
grac97's Avatar
I got a virgin p75 for 30 bucks firm let me know 813 4846495 it came off a 97 integra ls
