ecu question
Old Jan 31, 2009 | 05:33 PM
gribblek's Avatar
Default ecu question
just got a b16a1 swap and kid had a 37820-p2p-a71 ecu now thats for a ek four door at will it work or do i keep the p28 thats in my eg and keep it obd1 what do i do
Old Jan 31, 2009 | 05:37 PM
gribblek's Avatar
any body
Old Jan 31, 2009 | 07:16 PM
eightwun3zfynest's Avatar
sleeper
you can keep the p28 and chip it with the jdm pr3 maps. but youll have to get it tuned and tell the tuner what mods you have on the motor so proper tuning takes place. or till you wana tune it get the pr3. but if the ek got a b16 in the car it should work. but if your already wired for vtec in your eg stay obd1. no reason for rewire if already wired for vtec
Old Feb 1, 2009 | 09:00 AM
gribblek's Avatar
so will my car run with the p28 untill i get it tuned
Old Feb 1, 2009 | 04:05 PM
mtber's Avatar
I would not recommend running a stock b16 on a stock p28. It can be done, however I would not put the motor into high load conditions.
You should have the ecu tuned for the motor you are running.
Old Feb 1, 2009 | 04:18 PM
biggoofy's Avatar
S1's body guard
tune!!!!!!!!!!
SQUADRON ONE
NIKON D60 / 18-55 VR / 55-200 VR /
1994-integra ls j fronted on boost 348whp
1996-integra ls-vtekkk dd
Old Feb 2, 2009 | 09:02 AM
sleeper
it might run but i dont recommend running it without tuning it first. even if its a stock motor you still get more power out of the p28 ecu rather than the p2p or the pr3 .. but get the pr3 obd1 till you have the money to put a few mods and do the p28 but obd1 is the way to go ...
Old Feb 2, 2009 | 09:37 AM
Nandosol's Avatar
Garage Slut
the p28 is meant for a single cam vtec motor. If you absolutely need the car to run, do not go above 3-4k RPMs if you are using this ecu. Have someone socket it and burn you p30(obd1 b16 maps) maps onto your chip. Then you will have your car running right, and ready for whatever extra mods you want to throw at it. Or you could just trade your p28 for a p30 and be done with it no extra socketing/chipping needed.
Old Feb 2, 2009 | 09:44 AM
sleeper
^^ nando sol is the best he knows is ish. he helped me out a bunch listen to him ..
