H22 swap
Old Jan 28, 2009 | 05:53 AM
DRIVEITHARD's Avatar
REV IT UP
Default H22 swap
Ok guys I have a question about my front springs.I have lowering springs all around my ek.I'm putting h22 in and I need to know what springs I will have to use to match up once swaped.Hope someone has done this before and might know.Thanks for any help.
Old Feb 1, 2009 | 07:38 AM
REV IT UP
Even if someone could tell me the weight difference between h22wtranny vis d16w tranny.
Old Feb 2, 2009 | 09:06 AM
eightwun3zfynest's Avatar
sleeper
well seeing how the h22 is a 2.2 and the d16 is a 1.6 there is alot of weight difference .. but you shouldnt have to change your springs. i have lowering springs from eibach with the strut(the whole set) and all i gotta do is raise up the front a lil to make sure motor dont hit ground or so it dont look like your front is lower then rear. just get goot springs
Old Feb 2, 2009 | 03:39 PM
REV IT UP
Ya I have lowering springs not coil overs.And with my 18's it sets almost on top of the tires.That is why I was asking.This way I can get a set costum mad for the right weight and hieth.
Old Feb 2, 2009 | 06:02 PM
PooN_Lude's Avatar
No need to swap out your springs, Believe it or not the weight difference between a B series and an H series is minimal. You should already have aftermarket shocks for your lowering springs, that would be the only thing I would worry about.
Old Feb 2, 2009 | 07:06 PM
solsi2000's Avatar
i went from a d to an h22 in my old sol and i didnt thave to change out the springs. the ride actually felt smoother to me.
03 Jetta 1.8t FS/FT clean
https://www.tamparacing.com/forums/c...lots-pics.html
