Old Jan 26, 2009 | 03:37 PM
Stealthracing's Avatar
STEALTHAUTOWORKS
Default ???????????????????????????
CLUTCH SLIPPING......1 MINUTE IT IS FINE THE NEXT IT SLIPPED THEN THE CAR COOLED OFF AND IS PERFECTLY NORMAL................ IS IT POSSIBLE TO BOIL THE FLUID IN THE SLAVE CYL. AND CAUSE IT TO SLIP?????CLUTCH IS IN GOOD SHAPE JUST INSTALLED
I HAVE 4-1 HEADER ITS ABOUT 2-3'' AWAY FROM THE SLAVE.....ANSWERS WILL BE REPPED......I'M PUZZLED
Bump my s**t get REP
Old Jan 26, 2009 | 04:41 PM
343whpDelSol*'s Avatar
What type of fluid have you used? did you just use like a dot1 or something fluid? or did you use like a Dot3 synthetic for the higher heat? Did you bleed the system again when you put in the new clutch or not? there may be an air pocket too
98 Eddie Bauer Explorer with single 12W7: 7th loudest vehicle in PA: Sold
93 Gutted Greddy Turbo and Zex Nitrous EG Hatch: Sold
07 Caliber with 13W7 and 20's: Traded
08 Ridgeline with all JL system: Traded
94 343whp D16z6 Del Sol: Sold
04 VW R32: Doin' Thangz
Old Jan 26, 2009 | 05:44 PM
DemonCivic's Avatar
did you resurface the flywheel?
what type of clutch?
Old Jan 26, 2009 | 05:46 PM
94jdmeg6civic's Avatar
your header is not the problem i have a rmf narrow and it almost hits it
do you have oil or something on your flywheel and what are the miles on it ?
Old Jan 26, 2009 | 06:05 PM
STEALTHAUTOWORKS
Clutch Has Been Installed For A Week! Stage 2 Clutch,act Lightened Flywheel! Motor Was Just Rebuilt So I Know There Is No Oil On The Flywheel.. It Has Less Then 150 Miles On Motor,clutch!!!!!!!!!!!when It Started To Slip The Pedal Got Rock Hard.........
Old Jan 26, 2009 | 06:06 PM
STEALTHAUTOWORKS
U All Have Been Rep'd!!!!!
Old Jan 26, 2009 | 06:25 PM
StreetBlitz's Avatar
B Tuned CRX
I've only delt with hydro trannys, mine would slip off and on... found out there were air pockets from when we pulled the thing out. Get some clutch fluid, and bleed it. Hope you figure it out.
Old Jan 26, 2009 | 06:39 PM
DemonCivic's Avatar
sounds like it may be a heat issue like you thought. try bleeding the entire system and replacing with a higher grade of fluid, my choice would be Castrol GTLMA
Old Jan 27, 2009 | 10:32 AM
Cone Killer's Avatar
Can't be the slave cylinder, if the slave or fluid were bad, the clutch would catch instead of slip. The slave is basically "dead" until fluid pressure is applied, in theory, you could drive the car with no fluid in the slave system, you just would have a hard time starting and stopping.
Sounds to me like you either have some oil on the clutch disc or the pressure plate has issues.
Old Jan 27, 2009 | 06:16 PM
freakasis's Avatar
or the fork is not installed properly. but its def not a master/slave/fluid issue.
"Black people can't be racist" - Some black guy.
